Maryland battery meet at Sport Chevrolet in Silver Spring
Grab our Forum Feed
+ Reply to Thread
Results 1 to 10 of 10
Thread: Maryland battery meet at Sport Chevrolet in Silver Spring
  1. #1
    Join Date
    Oct 2011
    Location
    Timonium, Mays Chapel, Maryland
    Posts
    484
    Default Maryland battery meet at Sport Chevrolet in Silver Spring
    We had a great turnout today at Sport Chevrolet in Silver Spring, Maryland. About a dozen owners showed up with their Volts. Sport Chevrolet had a battery out of a Volt that being serviced for the battery structure upgrade. The battery was on the special stand that's used when the battery's removed and we were able to walk around under the car while it was up on the lift, checking out all of the details that we normally can't see.
    Sport Chevrolet also showed an impressive video that GM has provided dealers to show the details of the battery structure upgrade. This upgrade involves many more steps than I would have imagined and is unbelievably thorough. Sport has already completed five battery upgrades, and given the complexity of this job, I want to entrust my Volt to a dealer that has experience with it. Four of us signed up for appointments with Sport Chevrolet for precisely that purpose.
    First, here's our group gathered around the removed battery. GM has designed a special wheeled stand for lowering the battery out of the car and moving it out of the way while the upgrade is made under the car. The battery assembly has a metal flange around the bottom edges that bolts to the chassis. The flange is visible in all of the photos of the battery.
    The business end of the battery with all of the connections and the Sport GM explaining it all:
    Here some of our group check out the underside of the car where the battery mounts. Although it doesn't show in the photos, the whole underside of the car is sheathed with a stiff plastic liner that keeps dirt and debris from fouling the works.
    One of our group inspecting the black brace that's been epoxy glued, riveted, and bolted to the chassis. GM provides all of the parts, glues, glue applicators, etc. that are need to do the job. The brace is the key part of the modification and requires drilling over 20 holes. The battery coolant system is also upgraded and a special protective device attached to the filler to prevent unauthorized persons (read do-it-yourself mechanics) from messing with it.
    Here's a shot of all of the connections from the car to the battery. All of these have to be disconnected and reconnected when the battery is removed and reinstalled. The technician told us it takes about 90 minutes to remove the battery. It weighs about 500 pounds he told us. The special stand braces the battery as the mounting bolts are removed then safely lower it down so it can be rolled away.
    Here were all watching the GM training video it provides on the battery structure fix to dealers. It's about 30 minutes and provides great detail. We were all amazed about the thoroughness of this upgrade. Given what the dealers have to do, it's not surprising that the fix takes at least a day. Sport Chevrolet asks that owners leave their Volts for two days and provides a free loaner for the duration.
    Sport Chevrolet had four Volts on the a showroom floor dedicated to the Volt. They told us they've sold 86 Volts. This is a very impressive dealer with a very impressive staff, and extensive experience with the car, which I think counts for a lot. Even though I live almost 40 miles away in Baltimore, I'm going out of my way to have my Volt serviced there.
    After the event 6 of us went to lunch at a nearby restaurant at a mall with 6 new charging stations. While we ate lunch we all charged our Volts. Being good Volt citizens and marketers, we explained to the manager of the restaurant that she should advertise the presence of the charging stations, as it would result in business from people like us. As she was neither aware of the Volt nor the nearby charging stations, we also took her outside to check out our cars and the charging station set up.
    In all it was a fantastic day, and a great experience to spend so much time trading information and stories with other Volt owners.
  2. #2
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,514
  3. #3
    Join Date
    Feb 2011
    Location
    Fallston Md.
    Posts
    418
    Default
    I was also very impressed by the presentation and all of the info that we recieved to help curb any fears about doing the repair. I also would travel the 54 miles from my home to have the upgrade done if I was not also impressed with my current dealer. I enjoyed seeing all of the Volt owners and sharing our thoughst about the fantastic car that we have all purchased. It was also nice to meet Monica Murphy GM Manager Advanced Technology Demo Programs. The red volt on the lift was one of her groups 2 Volts that they use for transportation.
    On a side note they also showed us the new power cord from the recall and told us that you can return more than one for free replacement if you have a backup. He also said that it does not matter where the second one was bought.
    2012 Blue Topaz Volt
    VIN # C07798 Born 10/25/11.In service 11/7/2011
    Geo-Thermal Heat & A/C
    6.7 KW Grid-Tie Solar
    Solar Reflective Roof
    https://www.voltstats.net/Stats/Details/278
  4.
    Advertisement
  5. #4
    Join Date
    Oct 2011
    Location
    Posts
    484
    Default
    Jim,
    Great to see you again. We need to do these kinds of events more often
  6. #5
    Join Date
    Mar 2012
    Location
    Palatka, FL
    Posts
    115
    Default
    Excellent event at Sport Chevrolet. Wish I were in the area to attend.
    "I think that the Volt has garnered more awards than any other vehicle in history." Bob Lutz
  7. #6
    Join Date
    Jan 2012
    Location
    Silver Spring, MD
    Posts
    59
    Default
    This was an excellent event. Thanks to those who arranged it for us.
    From 05 Mustang GT to a 2012 Volt - Premium package, navigation, Red, Backup camera package
  8. #7
    Join Date
    Sep 2010
    Location
    Timonium, MD
    Posts
    381
    Default
    I thoroughly enjoyed the meet-up and Sport Chevrolet's hospitality. I too have some photos that I'll post shortly. The battery enhancement is much more involved that just adding some reinforcing plates. I'm glad I got to see it in detail. I plan on having this done, but I'm not in a hurry.
    It was great to see all the Volt owners! We come from all different backgrounds, but we all agreed that the Volt is wonderful car!!
    Thanks to all for the great day!!
    Volt 63
  9. #8
    Join Date
    Aug 2011
    Location
    Waldorf, MD
    Posts
    296
    Talking Very informational, even for someone who doesn't own a Volt
    Here are more photos of the event (thanks Rick for starting this thread and posting some excellent photos!):
    http://www.meetup.com/MDVolt/photos/7268862/
    We want to thank Monica Murphy (General Motors), Randy Chiswell and Rob McBride (Service Management at Sport) for taking the time out of their holiday weekend to show us the enhancements.
    Mark
    Organizer
    PS: I hope GM considers doing this in other parts of the country, because I believe the owners really appreciated it. While a handful of owners immediately signed up to have it done, at least one other attendee decided he wasn't going to do it.
    Also, check out Rick's Volt after market enhancements in the meetup group's event photos, I think you will like them!
  10. #9
    Join Date
    Mar 2011
    Location
    Northern Virginia
    Posts
    131
    Default
    Thanks to all of you for the information and pictures. It looks like Sport Chevrolet is on to a good thing - - great for the Volt and Volt owners!
    2011 Viridian Joule Tricoat Volt #3850, Placed in Service 20 June 2011.
  11.
    Advertisement
  12. #10
    Join Date
    Feb 2012
    Location
    SF Bay Area
    Posts
    202
    Default
    Very Cool!
    Thanks for sharing the pics and descriptions.
    So much Hardware! So much Software! So many Electrons! And it's got Tires, too!
    #8954 "DasVolt"
    2012 Volt, Black, Light neutral leather interior/ Dark trim accents, Premium Trim Package, Polished Aluminum Wheels, Bose Premium Audio System, Navigation, Rear Camera/Park Assist.
    Ours on February 14, 2012
Similar Threads
  1. Replies: 9
    Last Post: 04-05-2012, 10:36 AM
  2. Meet Your 2012 Chevrolet Volt
    By Slapshot28 in forum Chevy Volt News and Events
    Last Post: 06-10-2011, 01:26 PM
  3. Saw Three Volts Today - Silver Spring, Maryland - Sport Chevrolet
    By Electric Lurker in forum Chevy Volt News and Events
    Last Post: 01-07-2011, 04:35 PM
  4. i-MIEV battery confirmed to not meet US battery warranty requirement.
    By HyperMiler in forum Electric Car Competitors
    Last Post: 06-27-2009, 01:29 AM
  5. Silver Zinc battery
    By MikeKO in forum Lithium and Advanced Automotive Batteries and Charging
    Last Post: 08-16-2008, 05:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
