ICE fuel milage calibration
Grab our Forum Feed
+ Reply to Thread
Results 1 to 2 of 2
Thread: ICE fuel milage calibration
  1. #1
    Join Date
    Dec 2011
    Location
    Power Montana
    Posts
    166
    Default ICE fuel milage calibration
    We use the engine quite a bit, as our normal trips exceed EV range. Our ICE milage is normally indicated as mid to low 30's, best has been high 30's, by the car. I am wondering if this might be off slightly as when I fill up the most I have ever gotten in the tank was equal to what showed as used, but most of the fillups are .1 to .4 gallons less then shown as used. I am the only one to fill the car as my wife has no problem with the plug but won't touch the gas. Has anyone had the chance to check this calibration?
    Bill - Red Volt 6009
  2. #2
    Join Date
    Jun 2012
    Location
    Southlake , Texas
    Posts
    780
    Default
    It sounds like the calibration is spot on . The 0.1-0.4 is just the variance of how full you filled the tank . I got 43.3 mpg on my first time , 33.2 mpg on my second and 35.5 mpg on the third usage of the generator . The battery has given me a low of 37.5 and the highest so far of 43.3 miles .
Similar Threads
  1. Tire pressure calibration ???
    By notaguru in forum Volt Ownership Forum
    Last Post: 03-27-2012, 01:56 PM
  2. VIN# < 954? Volt Control Module Calibration
    By scottf200 in forum Volt Ownership Forum
    Last Post: 06-25-2011, 08:37 PM
  3. My Personal Best milage
    By Eric99 in forum Volt Ownership Forum
    Last Post: 05-27-2011, 11:08 PM
  4. low low milage per charge
    By berton893@sbcglobal.net in forum Suggestions for GM
    Last Post: 09-28-2008, 10:03 PM
  5. gas milage for e85 in volt
    By warwick76 in forum Newcomers
    Last Post: 08-18-2008, 03:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
