voltstats.net
Grab our Forum Feed
+ Reply to Thread
Results 1 to 10 of 10
Thread: voltstats.net
  1. #1
    Join Date
    Jan 2011
    Posts
    228
    Default voltstats.net
    when logged in on voltstats.net, i clik on manage groups and i get a server error either on my computer or smart phone. I cant join my Canadian friends, any idea?
    2011 - January 5, 2K deposit
    2011 - October 5th, official order of a blue Volt
    2011 - November, Order Accepted by GM
    2011 - December, VA says Volt to be built in the week of 16, Jan.
    2012 - Feb 17th, VA says Buzz's birthday is Feb 9th.
    2012 - March 8, C 14485, Buzz is home.
    Owner of the Holy Grail of cars , Take that Japan!
  2. #2
    Join Date
    Mar 2012
    Location
    longmont, colorado
    Posts
    227
    Default
    Same thing here. I guess patience is a virtue applies. Ray
    b2690
  3. #3
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,514
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Posts
    189
    Default
    Quote Originally Posted by Driverguy01 View Post
    I'm having trouble reproducing your error, can you give more information, like your car's serial number? Thanks.
    Volt #2163 in Kaukauna, WI
    Check out the Volt Stats Page!
  6. #5
    Join Date
    Jan 2011
    Posts
    189
    Default
    Nevermind, your serial number was in your sig, duh.
    I've found the bug, and I'll have a fix out soon. Thanks!
  7. #6
    Join Date
    Mar 2012
    Location
    Columbus, OH
    Posts
    26
    Default
    Got it updated!!!!!!!!!!!!! Thanks for all the help!!!!!!
  8. #7
    Join Date
    Jan 2011
    Posts
    228
    Default
    tks a lot it works fine now. Bet a few more will join, tks again mrosack. UPDATE: now i cant see the groups i joined.....HELP
  9. #8
    Join Date
    Nov 2010
    Location
    Vancouver, BC
    Posts
    326
    Default
    Autoblog picked it up: Volt Stats! lets owners share their data and compete
    In the comments, there is a dingdong of course
    Richard Phat Lam
    Keep in mind that the MPGe reported on VoltStats website is incredibly inaccurate. The designer of the website cannot pull KWh used from OnStar, so he has to assume a maximum efficiency of 93 MPGe and go down from there. Individual Volt owners can actually go on the MyVolt website run by Chevrolet to calculate their true MPGe. Mines is 33 KWh/100 Miles (33.7 / 0.34 = 102 MPGe) even with a full 100 MPH EV only uphill drive ;-). Volt Stats reports my Volt as 88 MPGe which is 15% under the true MPGe.
    So the fleet average MPGe is lower than the true MPGe.
    I agree entirely with you on this. I wish the my Volt would do the MPGe calculation on top of the standard MPG calculation. It is rather easy on my 2012 Volt 33.7 / (total KWh used/miles driven) = MPGe. You can then do average the two to get an rough estimate of total environmental impact your driving has done
  10. #9
    Join Date
    Jul 2009
    Location
    Colorado Springs, Colorado
    Posts
    2,866
    Default
    Quote Originally Posted by Voltastic View Post
    Not sure why you consider that a dingdong comment. Not sure about his data since he is depending on myVolt, but I do my own computations from data on voltstat.net and the my MPGg is way better than the EPA, so his overall statement is right. A Spread sheet to compute your own at
    http://innovation.uccs.edu/~tboult/V...a_withMPGe.xls
    I've spend enough time in the data on volstats that I also have more appreciation of the prolems at myvolt.com.. there are lots of "errors" in the reported data that makes it more difficult to work with. The spreadsheet makes some assumptions and may make errors).
    (Mike if your reading this, I'd be happy to work with you to add this to volt stats.. its spring break week and I can even sling some code, and can probably do better with a real programming language but was to painful to do some cleaning in excel without VB. ;-)
  11.
    Advertisement
  12. #10
    Join Date
    Jul 2011
    Location
    Memphis, TN
    Posts
    199
    Default
    I just started another thread on accuracy of the stats. My mpg has drifted about 400 mpg between web site and odometer estimates, which works out to over 0.8 gallon in missing gas. It's probably due to source stats, but if there are code changes to better handle things, that would be great!
    http://gm-volt.com/forum/showthread....yVolt-Accuracy
Similar Threads
  1. Question on VoltStats Website
    By agggilli in forum Volt Ownership Forum
    Last Post: 02-29-2012, 09:44 AM
  2. What does EV Mileage "PVD" mean on Voltstats?
    By MrEnergyCzar in forum Volt Ownership Forum
    Last Post: 02-14-2012, 09:59 PM
  3. Voltstats accuracy
    By dumluk2002 in forum Volt Ownership Forum
    Last Post: 01-29-2012, 02:19 PM
  4. Volt Disappeared from VoltStats.net....
    Last Post: 12-31-2011, 11:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
