New designed 110volt charger just released
Grab our Forum Feed
+ Reply to Thread
Page 2 of 7 FirstFirst 1 2 7 LastLast
Results 11 to 20 of 63
Thread: New designed 110volt charger just released
  1. #11
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    1,271
    Default
    IMHO, GM should replace them all, its a horrible design internally and the use of 16awg end to end is just down right risky. I suspect GM finally opened some up and had GM internal designers reviewing it, and with those results realized it presents to much of a risk, last thing gm needs is having a charger start a fire
    2012 Crystal Red Volt #10921 - Plug Powered #76
  2. #12
    Join Date
    Sep 2010
    Location
    Timonium, MD
    Posts
    381
    Default
    My Voltec Charger has been working just fine since I took delivery in December 2010. I've been watching the plug and the cord temps, but no issues at all. The input cord does get warm, but not what I would call hot. The plug stays cool if on the extension cord or plugged directly into my GFCI outlet, but gets pretty warm when plugged into my Kill-o-watt meter. I'd be interested in seeing the recall s/n's if available.
    Volt 63
  3. #13
    Join Date
    Dec 2011
    Location
    Central Ohio
    Posts
    67
    Default
    I have noticed that in this warmer weather, the 16 gage 120 plug end had been getting very warm, almost hot. I will be calling my dealer this week for an upgrade!
    2012 Crystal Red Volt #3491 - Purchased on November 28, 2011.
  4.
    Advertisement
  5. #14
    Join Date
    Nov 2011
    Location
    Tampa Bay
    Posts
    428
    Default
    I had mine replaced, I have used it maybe three times (usually use 240v). I measure the temp with a thermocouple inside the back cover where the wire goes in (between the plate that attaches to the wall and the unit) and it was interesting:
    It reached 140F, that pic was right after I unplugged it from the wall. Note the caribiner's I use to hang the unit so there is no stress on the cord. The dealer had told me to do that when I picked up this replacement charger to prevent the strain reliefs getting broken. I maybe used it 5x without the caribiners, and they still broke, hence one reason for the replacement. I got mine back in Dec or Jan I think, so maybe mine is the new one. But it still gets hot. It would be great if they do/did make it better.
    Edit to add it was 70F outside when I took the measurement.
    2013 Volt #D8115
    Formerly 2011 Volt #B1514
  6. #15
    Join Date
    Aug 2011
    Location
    North East Ohio
    Posts
    203
    Default
    Just had mine replaced around march 1st. Date is 1266048, catalog 2280-9287. Hope to find out if this is the new one or not. It doesn't look much different, but s/n is much higher than my original.
    I did notice that this will trip and reset up to 3 times with low voltage. I believe my old one would only trip once and then go flashing two red lights.
    Silver Ice #C4722 Oct 1, 2012
  7. #16
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,277
    Default
    anyone who thinks they might have a new type charger ; un-wind the cable and sent in a picture of the tag covered by the cable.
    The unit I got 2 weeks ago had a Date stamp of 1244066 part number 2280-9287
    ALSO note it is not UL but tested by Intertek - I am going to post a link to video of their testing of our charger
    the film shows the cord being stress tested and having it run over by a car wheel.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  8. #17
    Join Date
    Nov 2011
    Location
    Tampa Bay
    Posts
    428
    Default
    Looks like I have the new one already. My previous post, different date code:
    http://gm-volt.com/forum/showthread....227#post109227
    I really don't use mine much now, I use a chargepoint at work, and the Voltec 240V at home. Only if the chargepoint is blocked (yes, it happens) or I go somewhere else where I can plug in.
    2013 Volt #D8115
  9. #18
    Join Date
    Aug 2010
    Location
    Detroit, MI
    Posts
    2,002
    Default
    Quote Originally Posted by MTN Ranger View Post
    I wonder what the VIN range includes?
    I do not have a VIN breakdown with me right now, but if you would like, I can do a quick VIN scan and see if your Volt is included. If anyone else is interested, send me a PM and I can check it out for you.
    If you have any further questions feel free to contact the Chevrolet Volt Advisor Team
    (877) 486-5846
    New Volt Advisor Hours:
    Monday - Friday 8AM to 11PM EST.
    Saturday 11AM to 8PM EST.
    Closed on Sunday.
    voltsocialmedia@gm.com
    https://twitter.com/ChevyVolt
  10. #19
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,673
    Default
    Both of mine show up according to my local dealer.
    Diamond White #B2140 ecosister plate=SLRRYDER
    Crystal Red #C8885, Red-Rider plate=NO2OPEC
    No gas purchased, fully charged off Solar, OK so I bought some gas to go to Vegas!
    DRIVING for FREE! NO OPEC FEE!
    My TED 5000 power monitoring
  11.
    Advertisement
  12. #20
    Join Date
    Mar 2010
    Location
    SF Bay Area, CA, USA
    Posts
    333
    Default
    I just replaced the plug this past weekend on my 15 month old 120V charge cord. I noticed it was a bit swollen around the plug blades and a small amount of black goo from the plug plastic had either melted or chemically broken down over time and contaminated the blades. The old plug always ran warm along with the short cable between the plug and EVSE box but it was not hot enough that I thought it was dangerous. I had checked and removed the plug periodically during the last year and had not noticed any damage until just now. The new $6 replacement plug I got at the hardware store now runs cold and the short cable is now only the slightest bit warm.
    The answer is 0042.
Similar Threads
  1. Bridgestone's airless tires are designed to never go flat
    By Jason M. Hendler in forum Engineering and Design
    Last Post: 12-05-2011, 02:33 PM
  2. Voltec Chevy crossover designed by ME!
    By thatsanicepicture in forum Engineering and Design
    Last Post: 04-19-2010, 07:12 PM
  3. How I think the 8th Gen 2006-2008 Honda Civic was basically designed
    By SilverMayne in forum Engineering and Design
    Last Post: 12-19-2008, 10:09 PM
  4. How I think the 8th Gen 2006-2008 Honda Civic was basically designed
    Last Post: 11-21-2008, 10:35 AM
  5. Another E-rev to be released, but when?
    By Tagamet in forum Chevy Volt News and Events
    Last Post: 04-10-2008, 07:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
