Charging problem with 110 charging unit
Grab our Forum Feed
+ Reply to Thread
Page 3 of 5 FirstFirst 1 3 5 LastLast
Results 21 to 30 of 42
Thread: Charging problem with 110 charging unit
  1. #21
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,276
    Default
    let us know on the part number
    other reports said Part # 22865050 is the 3rd iteration
    we still need a picture of the tag on the unit under all the wrapped up cable.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  2. #22
    Join Date
    Mar 2012
    Location
    pa.
    Posts
    33
    Default
    Unable To Charge The Vehicle At A Remote Location?
    The 120 Volt Charge cord set (as known as Electric Vehicle Supply Equipment) needs to be plugged into a dedicated 15 amp or greater grounded electrical receptacle. If the customer is using an electrical receptacle (AC Outlet) from an unknown source (such as a hotel or motel), the charge receptacle may not be dedicated or may have some type of ground fault that would prevent the vehicle from being charged. When this occurs, both fault indicators on the 120 volt charge cord set may flash red and the charge status indicator will be yellow. The charge cord set is built to try to recover after a calibrated time period if it detects a ground fault with its electrical power source and then it may attempt to try to charge the vehicle again and it may charge ok for a certain period of time until the charge cord set see a ground fault again.
    If you experience this concern, please don't replace the charge cord set or any charger related parts on the vehicle. This may be a normal concern due to the condition of the charge receptacle or wiring at remote locations.
    Some of the items below may be suggested to the customer when using a charge receptacle at remote locations.
    1. Do not use an extension cord to extend the length of the charge cord set.
    2. Disconnect the charge cord set from the vehicle and the AC outlet and retry the procedure again using the reduced voltage mode.
    3. Try a different AC outlet at the remote location.
  3. #23
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,276
    Default
    That actually needs more information.
    1. its ok to have an extra cord of the correct type wire gauge.
    2. we set the amps not the voltage with the selection mode. 8 amp or 12 amps
    3. Yep always good info - but how about keeping $5 plug tester in the car before risking your charger to any 120 volt outlet.
    they will test for incorrect wires and missing ground wire for a little more you can see the voltage.
  4.
    Advertisement
  5. #24
    Join Date
    Mar 2012
    Location
    longmont, colorado
    Posts
    223
    Default
    Thanks regen, the problem was the 110 charge unit which Chevy replaced. All is good now.
    b2690
  6. #25
    Join Date
    Mar 2012
    Location
    United States
    Posts
    9
    Default
    Hopefully an isolated case. Picked up my replacement charge unit from dealer this past friday(4/6/12). The unit worked fine for two days. The third day the flashlight portion would stay on and not shut off. Unable to charge the car. I went to my dealership this morning and they confirmed that the charge unit was defective and give me a replacement.
  7. #26
    Join Date
    Apr 2012
    Location
    Milwaukee WI
    Posts
    5
    Default
    Ghost, Lefty
    Did the new units solve the Problem? My volt is one week old. After 4 days Started tripping breaker. Switched outlet and now fter 15 minutes of attempting to charge, the red fault lights on the charge unit flash and the car horn "chirps". Error message says "charge interrupted. Cords re not hot.
    Calling dealer Monday. hoping new charging unit in stock!
    2012 Crystal Red Volt
    " ...and may the odds be ever in your favor"
  8. #27
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,665
    Default
    Quote Originally Posted by Jaksown View Post
    Ghost, Lefty
    This sounds alot like there maybe an issue with the utility. If you replacement does the same thing start checking the line voltage. It could also be a poor neutral line back to the transformer.
    Diamond White #B2140 ecosister plate=SLRRYDER
    Crystal Red #C8885, Red-Rider plate=NO2OPEC
    No gas purchased, fully charged off Solar, OK so I bought some gas to go to Vegas!
    DRIVING for FREE! NO OPEC FEE!
    My TED 5000 power monitoring
  9. #28
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,973
    Default
    There is a recall on the Voltec 120 volt charger. Take it back to the dealer.
  10. #29
    Join Date
    May 2012
    Location
    Malaysia
    Posts
    15
    Default
    How to reset the Unable to charge message on the main display? I can not charge the car since last time it was tripped the fuse.
  11.
    Advertisement
  12. #30
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,665
    Default
    Quote Originally Posted by JoE2012 View Post
    So,you have a,disconnect charger,showing green lights? Withmitmdisconnected,the car shows this message? If you tripped the breaker disconnect from the car then reset the breaker, replugging into the car
Similar Threads
  1. CEL After Problem at Public Charging Station
    By magnushawk in forum Error messages/ health monitoring/ DTC's
    Last Post: 02-19-2012, 05:42 PM
  2. Q: Best Public EV Charging unit and/or Company?
    By Codyozz in forum Lithium and Advanced Automotive Batteries and Charging
    Last Post: 02-15-2012, 10:27 PM
  3. Problem Charging at Work...
    By JorgeM77 in forum Volt Ownership Forum
    Last Post: 11-01-2011, 10:07 PM
  4. After Charging
    By eplantz in forum Volt Ownership Forum
    Last Post: 06-18-2011, 09:18 AM
  5. Mobile charging unit
    By Michael in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 12-28-2010, 01:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
