Battery level indicator on dic changed on it's own to hollow gray outline indicator
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: Battery level indicator on dic changed on it's own to hollow gray outline indicator
  1. #1
    Join Date
    Feb 2012
    Location
    SE,USA
    Posts
    67
    Default Battery level indicator on dic changed on it's own to hollow gray outline indicator
    Weird thing happened this evening when I started the volt to come home from work. The nice green battery level indicator on the left side of the dic disappeared and was replaced by a small gray outlined battery in the same exact spot on the display. I have never seen this small battery before except when the car flipped over to the ice mode. Issue is that I still had 29 miles of estimated charge distance remaining. I looked in the owners manual to no avail. Anyone else see this? Wish that I would have had a photo of it, but didn't have a chance to get the shot. I powered down the car and restarted it and viola! The nice green battery reappeared! Seems like a bug or something.
  2. #2
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,659
    Default
    Someone mentioned a bug like this once before that I remember. I don't think it's been repetitive, or affected anything else with the car. Not confidence inspiring, but not actively harmful.
    Walter
    Volt FAQ
  3. #3
    Join Date
    Jun 2011
    Location
    Buckeye, AZ
    Posts
    95
    Default
    It's happened to me twice in 2800 miles. I rebooted and it came up fine each time. I wouldn't worry about it.
    RIP: C3344 adopted 11/7/11. Red, Blk leather/dark, Bose, Polished wheels.
    Fresh Start: C14506 adopted 3/23/12: as above
  4.
    Advertisement
  5. #4
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    1,440
    Default
    Quote Originally Posted by voltedge View Post
    While others have seen it happen a couple times, it is probably worth informing your Volt advisor. More instances of this occurring may Cause them to look into it further, and if solved, will only refine the overall Volt experience.
    Volt Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Leaf Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Commercial Level 1 Charging Station - Low cost solution suitable for Hotels, Employers, Airports, etc.
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic - Love the blue!
    [SIZE="2"]Driving for FREE with Solar PV!
  6. #5
    Join Date
    Mar 2010
    Location
    Hampton, VA
    Posts
    168
    Default
    I usually see something similar happen after I've done a remote start. Turning the car all the way on results in the greyed out battery indicator (probably a missed line of code to set it to the "active" image after a remote start is done). Rebooting the car will clear it up.
    I haven't seen the image change to the inactive version while the car is actively on battery, like the OP is indicating. Probably just a minor glitch that doesn't impact the driving of the car.
    Volt C-6178
    2012 Silver Ice Metallic, Camera, Nav/Bose system, cloth seats
    9 Jul - Order placed (1100) / 6 Oct - Produced (3800) / 27 Oct 2011 - Picked up! (6000)
    Last fill-up: 20 Feb 2013 / Last gas used: 21 Apr 2013
  7. #6
    Join Date
    May 2012
    Location
    Harrisonburg, Virginia
    Posts
    464
    Exclamation
    Mine just did the same thing. I was in the parking lot with vehicle off but the accesory power still on hooked to my smartphone that I was using via 12v outlet. After about 10 mins. all power shuts off to save battery (normal) but I was still using my smartphone for about another 5-10 mins while plugged into my 12v outlet. Once I finished up I started the car and proceeded to drive along in the parking lot and saw that my Volt battery in my dash was greyed out (41 EV miles remaining). So I snapped a picture. This never happened to me in the past. I normally don't mess with my smartphone in my vehicle which leads me to believe that it's connected somehow to my phone while being plugged into my 12v outlet in my center console but who really knows?? I put the car in N and pushed the off button and then pushed button back on to restart the car and now everything is normal. Everything has been working to the tee until this little snaffu, it only has 1,800 miles.
    2012 Crystal Red Tintcoat
  8. #7
    Join Date
    Mar 2012
    Location
    Boston
    Posts
    61
    Default
    I think the bigger issue is that the speedometer shows 9 mph when clearly you would have been stopped to take a picture :-)
Similar Threads
  1. Heat Status Indicator - what is it for?
    By dannyrusso in forum Mechanical systems
    Last Post: 03-22-2012, 11:28 PM
  2. The turn indicator sound sometimes misses a beat
    By Chris Harvey in forum Volt Ownership Forum
    Last Post: 11-30-2011, 05:00 PM
  3. Rear Seat Belt Reminder Indicator Operation
    By scottf200 in forum Volt Ownership Forum
    Last Post: 07-27-2011, 04:37 AM
  4. Miles showing on charge indicator
    By rmalzo in forum Volt Ownership Forum
    Last Post: 06-08-2011, 11:12 AM
  5. Replies: 10
    Last Post: 04-06-2011, 11:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
