Water in rear storage compartment
Grab our Forum Feed
+ Reply to Thread
Results 1 to 6 of 6
Thread: Water in rear storage compartment
  1. #1
    Join Date
    Aug 2011
    Location
    Ann Arbor
    Posts
    27
    Unhappy Water in rear storage compartment
    After pulling out the 110V charger this past weekend, I found a small amount of standing water on the right rear under floor storage compartment. After wringing out the rear compartment cover and using a few paper towels, its dry again. Any obvious sources (It hasn't been in the rain with the back lid open) that I should check? It has been snowy and rainy for awhile around here.
    Thanks
    Roger
  2. #2
    Join Date
    Oct 2010
    Location
    Lansing, MI
    Posts
    1,335
    Default
    Hi Roger,
    You have a leak; I would take the car to the dealership. Most likely culprit is hatch/deck lid rubber.
    When I wash the Volt, I use cotton towels to dry the sides of the hatch door as well as, the hatch door frame (top, sides, and bottom). If the hatch door frame rubber is bad, some of this water could come in. I also towel dry around the other doors, and under the hood.
    To find the leak, you can sit in the back with a flashlight, and have someone else drive the car through a car wash.
  3. #3
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,813
    Default
    There is a rubber bumper on each bottom corner of the hatch. I think they can be adjusted in or out. Perhaps one or both are too far out, preventing the hatch from fully sealing on the gasket?
    I too towel dry all those areas, as well as the gas and electric ports. I also wipe down the gaskets and once a month apply a little silicone protectant to them to keep them clean and squeek-free. I do this because I like the car looking like it came off the showroom floor. But you'll also quickly notice any issues.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 32,109 miles, 143 MPG, Remaining Oil Life 98%
    Typical Commute: 57-67 miles
    30 day Stats: 1288 miles, 250+
    MPG, 87% Electric, 13% gas, Saved 52 gal., 24 kW-hr/100 miles
    VOLT TIPS & SECRETS
  4.
    Advertisement
  5. #4
    Join Date
    Aug 2010
    Location
    Novi, MI
    Posts
    233
    Default
    Another thing to check: Most cars have a drain hole within the gasket track for the rear hatch. If that hole becomes plugged it can cause the water to go elsewhere...also that drain hold likely attaches to a hose which runs the water to a safe location on the bottom of the vehicle. If the hose wasn't installed correctly, it could be leaking into an interior area.
  6. #5
    Join Date
    Aug 2010
    Location
    Detroit, MI
    Posts
    2,067
    Default
    Roger -
    I'm so sorry to hear about the water you found in your rear compartment! I totally agree with JamesMcQuaid on this and recommend you take it into your local Chevrolet dealership to have them diagnose the problem. We want to ensure this is fully addressed for you; let us know if the Volt advisor team can be of any assistance!
    If you have any further questions feel free to contact the Chevrolet Volt & Spark EV Advisor Team
    (877) 486-5846
    Volt & Spark EV Advisor Hours:
    Monday - Friday 8AM to 11PM EST.
    Saturday 11AM to 8PM EST.
    Closed on Sunday.
    voltsocialmedia@gm.com
    https://twitter.com/ChevyVolt
  7. #6
    Join Date
    Feb 2010
    Location
    Maryland
    Posts
    208
    Default
    Do you ever use that 110V charger outside? In that rain/snow? Could that track in some water/melted snow?
    White Diamond Tricoat, Light Neutral leather
    05/12/11 1100 placed at dealership
    10/24/11 3800 produced
    11/5/11 Delivered!!!!!
+ Reply to Thread
Similar Threads
  1. Rear Compartment Storage Items
    By AZ-Volt in forum Chevy Volt Owners Forum
    Last Post: 05-14-2012, 07:30 AM
  2. Rear seat storage barrier question...
    By dafreak in forum Chevy Volt Owners Forum
    Last Post: 02-26-2012, 10:23 PM
  3. What is the LPO: “(RWW) Rear seat storage/barrier”?
    By scottf200 in forum Chevy Volt Accessories and Modifications
    Last Post: 01-02-2012, 09:57 PM
  4. Storage Under Rear Cargo Area
    By ClarksonCote in forum Chevy Volt Owners Forum
    Last Post: 01-04-2011, 08:21 AM
  5. Passenger Compartment Temp.
    By RLM in forum Suggestions for GM - Chevy Volt
    Last Post: 05-13-2008, 08:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
