Service Campaign #14114, RESS Battery Coolant Level Low
Grab our Forum Feed
+ Reply to Thread
Page 1 of 5 1 5 LastLast
Results 1 to 10 of 44
Thread: Service Campaign #14114, RESS Battery Coolant Level Low
  1. #1
    Join Date
    Oct 2012
    Location
    United States - MD
    Posts
    6,217
    Default Service Campaign #14114, RESS Battery Coolant Level Low
    http://www.thecarconnection.com/news...attery-cooling
    Found the above article randomly. I believe this was the issue I experienced in my '12 Volt last year, along with a bunch of others on here. I guess there was a quality control issue at the factory.
    2017 Arctic Blue Metallic Bolt EV
    Hidden Content
    Hidden Content
    My Bolt EV blog: Hidden Content
    cleantechnica.com and electrek.co: you suck, don't link my stuff
  2. #2
    Join Date
    Jun 2012
    Location
    Deerfield Beach, FL
    Posts
    431
    Default
    Took my 2013 in for an alignment last week and they took care of this campaign, too.
    "Faraday2" | 2017 Citron Green Metallic with Jet Black Leather. MyLink with Navigation & Bose, Driver Confidence Packages 1 & 2, Premium Trim, Delivered on 04/23/2016!
  3. #3
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    14,959
    Default
    Another reason to be proactive by checking your fluid levels from time-to-time. It takes only a minute. I do it weekly while I am washing the car and wiping down the engine bay.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Sep 2008
    Location
    my little grass shack
    Posts
    4,551
    Default
    I've mentioned this Service Update Campaign 14114 a few times before. (although it probably does deserve it's own thread)
    It only pertains to 2012-13 Volts.
    It is similar to the PIM software update in that it is to be performed on any MY12-13 Volts brought into the dealership for any reason.
    GM won't be notifying owners like they would for a "Customer Satisfaction" or "Safety" campaign.
    However some dealers may take it upon themselves to call in their Volt customers, which is fine.
    It's basically an escalation of preliminary bulletin PI0961
    The dealer will check the RESS coolant level, if low pressure test and inspect for any leaks (repair as required) and top up to the NEW revised coolant level.(see below)
    If any owners wish to determine if this campaign pertains to their car they can call your Volt Advisor or your dealer with your VIN
    WOT
    Welcome Hidden Content as our latest forum vendor!
    Follow the Chevy Volt and other GM electrified cars on Twitter! Hidden Content
  7. #5
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    14,959
    Default
    Is the 2011 recommended fluid level still at the seam, WOT?
    B3320
  8. #6
    Join Date
    Aug 2013
    Location
    Acton, MA
    Posts
    3,408
    Default
    Quote Originally Posted by bro1999 View Post
    I think the assumption that this was a factory quality problem is your guess, and I would not have said that without some proof. My understanding was that the coolant level was consciously set to the lowest level available (just over the sensor float) for a good reason: so that any leak would cause the car to stop using the battery, so that a leak in the battery itself would be detected early and have no chance of causing an electrical short (dried coolant is conductive). the "Bubble purge" is more of an unknown and I think is the reporter/writer's limited understanding or limited explanation of a more complicated situation in which varying tubing ID sizes at different temperatures can cause the coolant level to rise and fall more than was calculated originally.
    here it is, my thoughts for "new to you" volt (2011 to 2015) owners, right or wrong, in one post....:
    Hidden Content
  9. #7
    Join Date
    Sep 2008
    Location
    Posts
    4,551
    Default
    Quote Originally Posted by Steverino View Post
    No, the ideal RESS coolant level for all Volts is technically now at the revised level as shown above.
    But for most cars it's something that will very likely occur over the course of scheduled maintenance visits.
    There really hasn't been a method created to communicate this revised coolant level officially to dealers until the issuance of this campaign earlier this month. (as indicated by a few on here, they've been to dealers for maintenance with no addition of any coolant apparent on their repair order)
    Other than of course the earlier preliminary bulletin but that specifically pertained to cars that already had the "Service High Voltage Charging System" message due to low coolant.
    WOT
  10. #8
    Join Date
    Oct 2012
    Location
    Malibu
    Posts
    63
    Default
    We took our Volt to Keyes where we purchased it for it's first tire rotation and the power inverter updates. We have had the car for 18 months, but just recently went over 7,500 miles. When dropping it off, I mentioned that there was a new service campaign regarding the coolent level and to check it as when we checked it one side was at the top, but one side was lower at the seam. The technician said only the inverter bulletin showed up, but he put down to check the coolent levels. When we picked it up, the levels seemed the same as when we dropped it off (we made sure to look) and the rep checked with the service manager and he said they level was where it was supposed to be. I pointed out that the new level should be at the top of the black sticker, but his answer was the service manager said the levels were where they should be (and he seemed to imply that since one side was to the top, that was probably all that was required). Since it was late in the day and it already took the all day to rotate tires, change the oil and do the inverter bulletin and we needed the car back, we just picked it up and took it home for now and will just take it to another dealer closer to home if needed. I am attaching two pictures of the current coolent levels and am asking for your opinions on whether Keyes service department is not quite up to date with their service campaigns etc. and if we should be looking at taking it in to a different dealer for the coolent service. Keyes is actually a 45 minute drive from us and there are several closer dealers. Here are pictures from two different angles (sorry they show upside down.. could not figure out how to flip them ). Thoughts or opinions anyone.....??
    2013 Cyber Gray, Black Premium Leather, Safety 1&2, Bose and Navigation
    KWH RIDE
  11. #9
    Join Date
    Sep 2008
    Location
    Posts
    4,551
    Default
    It's low (by the current standard) but not to the point where it would trigger the code.
    Did you give them the campaign number? That should have have been enough!
    If it helps others it is GM Document ID: 3938762
    Unfortunately we can't post the actual paperwork here in these forums (due to copyright) but going forward I recommend calling ahead with your VIN to make sure your car shows up in GMs IVH system as having a "Required Field Action" for this campaign.
    WOT
  12. Advertisement
  13. #10
    Join Date
    Oct 2012
    Location
    Malibu
    Posts
    63
    Default
    Unfortunately I could not find the specific number on my phone when we dropped it off (and I forgot to write it down) or when we picked it up and since I was not going to leave it there (it was just as they were closing) we stopped trying to convince them. Keyes appeared to be really swamped when we dropped it off at 9:00 am and even with an appointment, it was not ready until just before closing so maybe they just did not want to deal with it and the testing it requires. Maybe all the recalls they are dealing with.... Will try another closer dealer at some point in the near future but it is at least good to know that it is at least not too low at the moment!
    Thanks!!!
    KWH RIDE
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. What is the PROPER battery coolant level?
    By FrankIII in forum Care, Maintenance & Service - Chevy Volt
    Last Post: 09-07-2016, 12:04 AM
  2. Service high voltage charging system - NOT Low Coolant!
    By Turboba6 in forum Generation 1 Volt (2011-2015)
    Last Post: 09-15-2014, 10:04 AM
  3. New service bulletin re: low coolant sensor
    By dgruber in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 09-17-2013, 10:12 AM
  4. My battery coolant level
    By Voltaic in forum Generation 1 Volt (2011-2015)
    Last Post: 07-02-2012, 03:02 AM
  5. 'High voltage battery' and the 'power electronics' coolant levels not user service?
    By maestro77 in forum Chevy Volt Engineering and Design
    Last Post: 10-30-2011, 02:23 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
