So I was driving along in my Volt and wanted the fan on. So I turned it on.
I got heat and massive power drain. WTF?!
See the attached photo. Is this a glitch or is the system operating as designed?
-Drew
-Drew
I think it is because you have it on Auto and the Temp on 74. It also looks like you may have a defroster on. I keep my temp all the way up in Eco { being pretty cold out lately } with the fan on 4 and the percentage usually reads 59%.
2012 Blue Topaz Volt
VIN # C07798 Born 10/25/11.In service 11/7/2011
Geo-Thermal Heat & A/C
6.7 KW Grid-Tie Solar
Solar Reflective Roof
https://www.voltstats.net/Stats/Details/278
I have similar quelms with 'fan only' operation. Today I had temperature set to 'LOW', fan in the speed 1 position and it was still using 25%. Huh? Really? 25% to just operate the fan at speed 1? I just turned it off and cracked the windows.
If ANYONE figures this out please let me know. There should be a way to run the fan without A/C compressor or heater engaging.
The heat should not say "on" with "Fan Only" set, unless you are using your Defroster. That seems strange. The percentages are just estimates, I worry less about those.
Volt Emergency Power Wiring Kit - Provide backup power to essential appliances.
Leaf Emergency Power Wiring Kit - Provide backup power to essential appliances.
Commercial Level 1 Charging Station - Low cost solution suitable for Hotels, Employers, Airports, etc.
Join thE REVolution
2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
2013 Volt #43404, Blue Topaz Metallic - Love the blue!
[SIZE="2"]Driving for FREE with Solar PV!
That's funny because I had the same situation today. I had to use the defroster and manually was turing it on and off as needed. When the defroster was off, I had it set to fan only, 72 degrees and I was noticing that the heat was stuck on. I turned the system off and turned the fan back on and it still showed that the heat was on. I ended up driving the rest of the way with the system turned off.
I believe this is caused by the auto-defrost setting
You can turn this off by pressing the config button, select Vehicle on the bottom, select climate and then un check auto defrost
In the posted picture, the defrost Icon is indicating it is ON
2012 Crystal Red Volt #10921 - Plug Powered #76
After looking at the owner's manual, this setting may be the problem: Auto Defog: The system will monitor high humidity inside the vehicle. When high humidity is detected, the climate control system may adjust to outside air supply and turn on the air conditioner or the heater. The fan speed may slightly increase to help prevent fogging. When high humidity is no longer detected, the system will return to its prior operation. To turn Auto Defog off or on, see “Climate and Air Quality” under Vehicle Personalization on page 5‑53.
I checked my setting and it was turned on.
Good find. I'll try that out. Hopefully that will solve my mystery.
Does anyone have a baseline for what the percentage _should_ be for fan only, speed 1?
Volt C-6178
2012 Silver Ice Metallic, Camera, Nav/Bose system, cloth seats
9 Jul - Order placed (1100) / 6 Oct - Produced (3800) / 27 Oct 2011 - Picked up! (6000)
Last fill-up: 20 Feb 2013 / Last gas used: 21 Apr 2013
