reply to "The manual does not say that you should not use a GFCI outlet. However, it says that if you need to use an extension cord, it should be 12 or 14 AWG and GFCI protected."
Yes .. that is correct .. you should use a larger size wire if you are going to add to the existing cord... you are adding to the length with a cord so it should be larger not the same size.
