A Rant: Ending the Volt's Power to Play with Your Mind and the "Efficiency Game"
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
Thread: A Rant: Ending the Volt's Power to Play with Your Mind and the "Efficiency Game"
  1. #1
    Join Date
    Oct 2011
    Location
    Cary NC - central North Carolina just east of Raleigh
    Posts
    208
    Default A Rant: Ending the Volt's Power to Play with Your Mind and the "Efficiency Game"
    A lot of posts on this forum revolve around the efficiency of the Volt and getting the most out of the car's range. The 40-Mile club . . . Posts on if, how, why, and when running in Mountain Mode improves CS efficiency or not, and how to use it best . . . should you or shouldn't you drive in L to gain a few tenths of mile per kWhr . . . "games" you cam play with the Climate settings to improve range.
    The nature of the car, and its displays, promotes awareness of and efforts to improve energy efficiency. I suppose the nature of the drivers has something to do with it, too.
    And I dove into that whole energy efficiency thing for the past two months since I got the car: I worked at it until I got up to 47 miles on a charge back when it was warmer (43 miles in a day with an estimated 4 left when I got home), etc. Calculated mpg equivalent and miles per kWhr and all that . . .
    IT GOT REALLY ANNOYING after a while. I was paying more attention to the car, not to my errands and other, more important things. Whenever I went everywhere I kept obsessing on whether driving this way or that would save a few watt-hours of energy. ENOUGH!!!!
    Last Monday it was really cold (for NC). I did no pre-heating. I got in the car, put Climate in comfort and cranked the heat up to 72 degrees, turned on the seat heater, put it in Sport (I always do-like the feel), and L (not for efficiency, I like the engine braking rather than the coasting of D), and drove to work just like I would have in my old Lincoln. I went through the Starbucks as always, but left the car window down while at the drive thru window, with cold air wafting in that battery power would have to heat up.
    AND EFFICIENCY WENT DOWN THE TOILET, BUT I DON"T CARE!!!! Even in cold weather, I used to get to work (11 miles) and the car would estimate it had 27 - 28 miles of range left. Last Monday, the first day of my "I don't care" routine: it said I had 18 left. Fine - I'll get home on electric and if not, there's a full tank of this stuff called gasoline. .
    After a week of this, the car is entirely satisfactory - finally. I get in, I start it, and I drive to work -- the errands and home in the eveing. I never ran out of battery. I never worry or focus on the car. It's doing just what I bought it for - finally.
    I love it.
  2. #2
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,641
    Default
    This is one of the wonderful things about the Volt...
    There are lots of things a person can do to optimize their usage if they want to (as you no doubt know,) but it really can be dropped into your life and used like any other car without a second thought - and even then, it'll deliver lower running costs than pretty much anything else you can buy right now. It's a real car with unreal efficiency, and anyone can drive it without knowing anything about it or worrying.
    Walter
    Volt FAQ
  3. #3
    Join Date
    Sep 2011
    Location
    Hampton, VA
    Posts
    329
    Default
    If I have days/thoughts like that I just drive our Prius.. The heater in that car is fantastic even when it is rediculously cold outside, and it is available within maybe a minute or so of pressing the power button. I myself am perfectly fine driving the Volt in EV only and sacrificing what I have to sacrifice. That is the beauty of the Volt is that you can use it however you wish either for maximum efficiency or maximum comfort. I only have a 9.9mi drive to work so I too could use the heater in the Volt on max the entire drive and still max it home on EV. I just chose not to.
    2012 Nissan Leaf SL #16790
    2012 Chevy Volt #2395
  4.
    Advertisement
  5. #4
    Join Date
    Dec 2010
    Location
    West Virginia
    Posts
    766
  6. #5
    Join Date
    Dec 2010
    Posts
    802
    Default
    I'm with you, Lee. I still make the occasional slight sacrifice, like if I can get away with Fan Only, to extend my electric range, but in general I'm not really willing to sacrifice comfort and convenience on the altar of the numbers game. And it's still nice to know I'll use less gasoline than 99.9% of drivers out there, no matter how I drive it.
  7. #6
    Join Date
    Feb 2008
    Posts
    397
    Default
    HAHAHAHAHA!!!!!!!!!!!!!!!!!
    I am only laughing because a few weeks ago, I was sitting in my car freezing my butt off (daytime driving lamps off, and climate control off), because I wanted that range as high as possible. Then I realized, that like you, I was going to get home with plenty of battery range left anyway. So on went the heat, and now I don't turn off those lights every time I get in the car.
    So what if the range is only 31 miles. I still don't use any gas, except on Tuesday, when I am on the road for 70 miles. And that huge 8.5 gallon tank of gas will still last me two months!
    And I have to say that it is a lot more fun to drive when my feet aren't cold.............
    C-5277
    Merry Christmas Everyone!!!!
  8. #7
    Join Date
    Oct 2011
    Location
    Gadsden Alabama
    Posts
    151
    Default
    I when through the same thing last week. I charge at home and at the office, and I am getting to work with 18 mile left (+- 5 depending on the weather). So, I said what the heck, and I turned the climate control on confort and forgot about all of the braking etc., and the car still does great. However, it is fun to try to get the most out of the car.
  9. #8
    Join Date
    Aug 2011
    Location
    North East Ohio
    Posts
    203
    Default
    When I can charge at work I will do the same. As I am 42 miles roundtrip, I need to make the car work for me, as the less gas I use, the more it justifies the high cost of the car. Its just who I am.
    Silver Ice #C4722 Oct 1, 2012
  10. #9
    Join Date
    Sep 2011
    Location
    Clovis, CA
    Posts
    59
    Default
    Quote Originally Posted by Lee Willis View Post
    I love it.
    I couldn't agree more. Someday we'll read about specialized therapy for EV range syndrome sufferers. I was doing the same thing even though I get done with my day with plenty of range left. I haven't gone cold turkey but I'm working on reducing range thoughts. As a note, my engine came on the other morning for maintenance. It ran for maybe 5 minutes and used .07 of a gallon. I was pissed...
    2011 Silver Metallic
    Premium Trim Package
    Jet Black Leather/Dark Accents
    Rear Camera/Park Assist
    Polished Alloy Wheels
    3671
  11.
    Advertisement
  12. #10
    Join Date
    Mar 2011
    Location
    Erin,ON
    Posts
    822
    Default
    LOL! I hit that wall the other day when in the real cold weather the car started the ICE to provide heating not energy. That's the great thing about the Volt, if you want to go all super efficiency you can, if not just enjoy the car like you did all your other cars! It's fun to drive both ways. No need for EV-OCD!! LOL
    2012 Volt Topaz Blue Metallic C4773!! aka HAL
    http://www.voltstats.net/Stats/Details/226
Similar Threads
  1. My Volt's "Birthday"?
    By DanGentry in forum Volt Ownership Forum
    Last Post: 10-28-2011, 11:06 PM
  2. "Li-Ion Battery Fault, service within one day" and "Voltec propulsion system error"
    By Bert in forum Error messages/ health monitoring/ DTC's
    Last Post: 10-03-2011, 12:33 AM
  3. "I Volted Today" play on voting stickers
    By JasonSpangler in forum Volt Ownership Forum
    Last Post: 09-23-2011, 01:06 AM
  4. Blinking "D" (Drive), brief loss of power
    By mfennell in forum Volt Ownership Forum
    Last Post: 03-22-2011, 05:17 PM
  5. Boston-Power are aiming for the car market with their "Swing" batteries!
    By Andre in forum Lithium and Advanced Automotive Batteries and Charging
    Last Post: 06-05-2009, 07:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
