Voltec charger plug
Results 1 to 8 of 8
Thread: Voltec charger plug
    Woodbury, MN
    6
    Default Voltec charger plug
    I bought a Voltec level 2 charger from SPX and had a local electrician install it yesterday. Everything seems to be working fine. But unplugging from the Volt is tricky. The plug seems to stick. Has anyone else had this experience? Any suggestions? Does it loosen up a little with use?
    If I am very careful to pull it straight out, it seems a little easier. But the plug on the included level 1 charger was nowhere near this "sticky" to unplug.
    5,463
    Ditto. I noticed the same thing. The 240v SPX Voltec unit is a tighter ("sticky") fit. The 120v is a much smoother in and out.
    Rancho Palos Verdes, CA
    2,122
    Aren't all J1772s supposed to be identical? I experience a bit of "stickiness" with both my 120 and 240v units. I think that you are right that the secret is to hold it straight. If I try to push it in on any angle at all it tends to bind. I find the plugs to be a bit on the flimsy side and I do wonder how they will hold up long term. I've been using mine since March, and so far so good however. Isn't J1772 an SAE spec? I guess/hope that they know what they're doing, LOL.
    5,463
    Spec or no, the 120v handle slides in easier than the 240v.
    Oct 2009
    Connecticut
    1,380
    Yeah, you get used to it pretty quickly. I have one SPX at work and one at home, both tight and secure.
    MrEnergyCzar
    My Chevy Volt Videos: One Year Review (click here) | Sexy Volt Car Wash (click here) |
    ................................Original Test Drive (click here) | 10,000 Mile Review (click here) |
    22,000 miles on 80 gallons | 100 miles per dollar (100 MPD)
    My Social Media Sites: http://xeeme.com/MrEnergyCzar
    09/30/2011 Delivered. (8,154th Volt Produced)[/QUOTE]
    Nov 2008
    110
    Try putting a little WD 40 or any lubricant on the edges where the plastic parts connect. It will really help making the connect and disconnect smoother
    Nashville, TN
    480
    Quote Originally Posted by Tim Hart View Post
    Careful which lubricant you use. Some will eat plastic!
    80303
    106
    I suggest paraffin or candle wax around the edge. Don't use any lubricant that could collect dust.
  1. Question about Voltec Charger
    By bmw323i in forum Volt Ownership Forum
    Last Post: 05-19-2012, 04:43 PM
  2. Voltec 120 Volt Charger
    By bizmodel in forum Error messages/ health monitoring/ DTC's
    Last Post: 07-21-2011, 12:21 PM
  3. Voltec Charger Part Nr
    By Voltorama in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 06-22-2011, 03:40 PM
  4. Voltec Charger Installation
    By Lyle in forum VOLT Consumer Advisory Board Discussion Forum
    Last Post: 05-25-2011, 12:23 PM
  5. Coulomb or Voltec Charger, 15A vs 30A?
    By ocryan in forum Volt Ownership Forum
    Last Post: 12-24-2010, 02:50 PM
