Battery Life Related to Level 1 vs. Level 2 Charging?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Battery Life Related to Level 1 vs. Level 2 Charging?
  1. #1
    Join Date
    Oct 2011
    Location
    Jefferson City, MO
    Posts
    27
    Default Battery Life Related to Level 1 vs. Level 2 Charging?
    Aside from the obvious convenience factor with Level 2 (240 volt) charging over Level 1 (120 volt) charging, is there any advantage for one over the other related to battery life? I know that thermal effects are very important in Lithium chemistry batteries, hence the sophisticated thermal management system in the Volt. Since the Level 2 charger can charge the battery in slightly less than half the time, this implies slightly over double the charging current with the Level 2 charger. This would also imply significantly increased heat within the battery due to the increased current flowing through the effective internal resistance. Does the battery TMS work during the charge cycle? Probably so. Are there any other positive or negative effects of using the Level 2 charger?
    BILL GERTH
    Jefferson City, MO
    2012 VOLT (VIN.........CU106509) Delivered 11/2/2011
  2. #2
    Join Date
    Oct 2009
    Location
    Connecticut
    Posts
    1,381
    Default
    The positive is you'll use less KWH hours to fully charge the battery. The fast charge doesn't effect the battery life, I used to think that but was told otherwise by the top people here. Probably because the on-board charger is less than 4 KW.
    Anyone here know why the battery life isn't affected?
    MrEnergyCzar
    My Chevy Volt Videos: One Year Review (click here) | Sexy Volt Car Wash (click here) |
    ................................Original Test Drive (click here) | 10,000 Mile Review (click here) |
    22,000 miles on 80 gallons | 100 miles per dollar (100 MPD)
    My Social Media Sites: http://xeeme.com/MrEnergyCzar
    09/30/2011 Delivered. (8,154th Volt Produced)[/QUOTE]
  3. #3
    Join Date
    Jun 2011
    Location
    Ottawa, Ontario, Canada
    Posts
    400
    Default
    Battery life is unaffected between L1 and L2 charging on the Volt because the L2 charging limit of the Volt (~3.3kW) distributed across all of the battery cells is still well under the threshold for decreased battery longevity of lithium-ion batteries. In hot weather, the TMS is undoubtedly essential for safely charging the battery at L2. In the Canadian winter for example, I strongly doubt that the battery would need any cooling even during an L2 charge...heck it might even need some heating!
    2012 Volt #C6688 Silver Ice Metallic (GAN), Premium Leather Seats with White trim (AFD), Bose Speakers (UQA)
    Placed order June 28 2011, built October 11 2011, drove home November 4 2011
  4.
    Advertisement
  5. #4
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,669
    Default
    Don't worry about it. Regen hits the battery with up to 50-60 kW at peak - driving in L hits with it 30 kW regularly.
    I've read that it's common for Lithium Chemistries to be ok with 2-3C charge rates, and that some are ok with 5C. For the Volt, as a 16kWh battery, that's 32-48 kW, or 80 kW. Level 1 charging is up to 1.4 kW, level 2 is up to 3.3 kW.
    You aren't even close to the range where heating/charge rate becomes a factor for durability (and yes, the TMS does operate during charging. I've occasionally poked my head in on the car and heard one of the radiator fans quietly whirring away.)
    Walter
    Volt FAQ
  6. #5
    Join Date
    Oct 2011
    Location
    Jefferson City, MO
    Posts
    27
    Default
    Quote Originally Posted by MrEnergyCzar View Post
    MrEnergyCzar
    Thanks for the quick response! That's good to know. Does anyone know how many KWH are required for a full charge in both Level 1 and Level 2 charging?
    In my situation and driving patterns, I have relatively short trips and can operate EV all the time, even with my Level 1 charger. It takes just a bit of planning, but being retired, scheduling of trips is pretty flexible. There are some situations where faster charging would be convenient. If I can get the KWH charging requirements for Level 1 and Level 2, I can do a quick calculation of how long it would take for me to recover the cost to go to Level 2 charging.
    I currently have a Kill-A-Watt meter to monitor my Level 1 charging. Is there a comparable metering system that will work on 240 volts?
    Thanks in advance for any info. BILL
    BILL GERTH
    Jefferson City, MO
  7. #6
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,698
    Default
    Quote Originally Posted by BILL GERTH View Post
    There is always a TED. Not cheap as a kill a watt though.
    Diamond White #B2140 ecosister plate=SLRRYDER
    Crystal Red #C8885, Red-Rider plate=NO2OPEC
    No gas purchased, fully charged off Solar, OK so I bought some gas to go to Vegas!
    DRIVING for FREE! NO OPEC FEE!
    My TED 5000 power monitoring
  8. #7
    Join Date
    Apr 2010
    Location
    Diamond Bar, CA
    Posts
    390
    Default
    I would not go to Level 2 charging based on the cost alone, as despite being more efficient, you're still counting pennies here. I think its something like 12 kWh on L2 versus 14 kWh on L1 but don't quote me. The main benefit is the time it takes, but if you're on Time of Use pricing, thats a bigger savings (getting hit by the higher rates would easily eat into any efficiency savings).
  9. #8
    Join Date
    Dec 2010
    Location
    Warren, MI
    Posts
    733
    Default
    To me the utility of L2 charging is if it enables you to charge the battery fast enough that you can use it that same day. If all you are doing is charging faster that the difference in small. They key is converting that faster charge into EV vs CS miles.
  10. #9
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,514
    Default
    Quote Originally Posted by petefoss View Post
    Indeed the primary reason I got it was I come home after work charge up and go out later. This was primary one day a week but it turns out I use this regularly on weekend and other days. It turned out EVEN more important in the winter because my range is close to 30 so other days of the week I use it.
    Also some have tight 'super off peak' windows so the short L2 charging is good for them.
  11.
    Advertisement
  12. #10
    Join Date
    Jan 2011
    Location
    SE PA
    Posts
    3,501
    Default
    Another way to look at it is the savings of fewer kWh per day across a multi-year ownership could pay for the 220V charger installation quickly. The short trips idea makes the 220V idea a good decision. It depends on how many charges you need to do, if you intend to remote-start and pre-condition in the colder weather. If you live in Sunny San Diego, 120V may work out fine but if you live in Buffalo or other colder climates, 220V is a good choice. Since the OP is in MO, the colder winter months could benefit from pre-conditioning with 220V.
Similar Threads
  1. Syracuse NY Level 2 Charging Stations!
    By ClarksonCote in forum Chevy Volt News and Events
    Last Post: 02-04-2013, 09:46 PM
  2. Will a level 2 charger be more efficient than the level 1?
    By AndrewW in forum Engineering and Design
    Last Post: 10-06-2012, 01:32 PM
  3. Will Volt Ever Have Level 3 Charging?
    By honoreitiscom in forum Volt Ownership Forum
    Last Post: 05-27-2011, 01:08 AM
  4. Wanted-Level 3 charging
    By George S. Bower in forum Suggestions for GM
    Last Post: 10-31-2010, 04:32 PM
  5. ORNL Level II Charger Reduces Charging Time to 45 Minutes
    By Jason M. Hendler in forum Chevy Volt News and Events
    Last Post: 04-27-2010, 08:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
