"Engine Running due to Temperature"
Grab our Forum Feed
+ Reply to Thread
Page 1 of 6 1 6 LastLast
Results 1 to 10 of 51
Thread: "Engine Running due to Temperature"
  1. #1
    Join Date
    Mar 2011
    Posts
    134
    Default "Engine Running due to Temperature"
    Last week when the morning temp was 25 degrees while driving to work, the display screen showed
    "Engine Running Due to Temperature". I called my Volt Advisor who said that the ICE kicks in when the outside temp is below a certain value and this is normal. During my 37 mile trip to work, the ICE ran for about 10 miles. When it was a bit warmer at about 28 degrees in the morning this week, I did not see this screen and the ICE did not kick in.
    Now that I think of it, when I got the Volt in April, the temps. probably never got down this low so I did not see this screen then.
    Has anyone else seen this happen at Cold Temps?
    Paul S.
    Red Volt# 2169
  2. #2
    Join Date
    Sep 2011
    Location
    Hampton, VA
    Posts
    437
    Default
    Have not had that happen yet. Only got down to 29 yesterday. However yesterday my car did tell me to "Drive Safely as There May Be Ice On The Roads." Or something to that effect. What made the situation humorous was that I had a sheet of ice on the windshield, so it should not have included the "may ice" in my opinion. All I could do was laugh as I sat there waiting for the windshield to defrost with the message displayed on the DIC.
    2016 Chevrolet Volt LT - Hidden Content
    14 Chevy Cruze Turbo Diesel, 12 Nissan Leaf SL #16790; Turned In: 12 Chevy Volt #2395
  3. #3
    Join Date
    Jun 2011
    Posts
    148
    Default
    I haven't seen it yet, it has only gotten down to about 28 here, but it is well known. I wonder - if you pre-heat the car while plugged in, would it avoid the ICE until it gets signficantly colder outside? I would hope the temp of the battery itself would be taken into account, not just the ambient temperature.
    DavidV
    Volt #2093 Crystal Red 48,218 miles 5816 gas miles 314 lifetime MPG
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Dec 2011
    Location
    Minneapolis
    Posts
    962
    Default
    This is normal operation. When the ambient tempurature in the engine gets to 25 degrees, it starts the engine to help protect the vehicle from being damaged.
    It's pretty annoying for those folks that count MPG like a religion (a lot of us). But it's really for the health of the car and is a good idea.
  7. #5
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    4,098
    Default
    See this post and the next several after it. A commonly discussed item around here.
    http://gm-volt.com/forum/showthread....732#post100732
  8. #6
    Join Date
    Jul 2009
    Location
    Colorado Springs, Colorado
    Posts
    3,141
    Default
    Quote Originally Posted by DavidV View Post
    Nope, its all about ambient temp (and after the ice runs the coolant temperatures).
    Now if Only I could find that temp sensor so I could give it its own little heater.
    Scott;s already posted other treads.. so much you can read there.
    BoultVolt Red 2011 #3745Hidden Content More freedom than electric.
    Personal best, Hidden Content
  9. #7
    Join Date
    Apr 2011
    Location
    Fort Collins, Colorado
    Posts
    665
    Default
    Quote Originally Posted by Paul Slazas View Post
    Attachment 4101
    Paul S.
    Red Volt# 2169
    In Colorado, it has been colder for a while. I see this regularly, but am glad it happens as opposed to the car just dropping my range like other EVs would do. This happens any time that the ambient temperature drops below 26F to warm up the battery. The ICE will run for a few minutes until the engine coolant temperature gets up over some set level (I have read on this site that it is 100F or so). This is done to keep the battery (that likes to run at 72F) operating at its most efficient.
    From my experience, pre-conditioning does not change anything and it is based upon the ambient temperature and not the core temp of the battery. I keep my Volt in a garage that stays pretty warm (~40F) even whrn it is cold (-12F a couple of weeks ago). When it is really cold, it takes a few minutes of driving for the ambient temperature sensor (shown on the center stack) to drop to 25F, but as soon as it does, the ICE kicks in.
    If you live in a cold area, you will use a little gas. Mine takes beween 0.03 and 0.07 gallons per "warm up" cycle. It usually only happens once on my 12 mile commute unless it is really cold and then it might be twice. The ICE will come back on if the coolant temp drops back down o some level (I don't know what that temp is).
    2012 Silver Ice Metallic - C4463
  10. #8
    Join Date
    Oct 2010
    Location
    Posts
    4,098
    Default
    Quote Originally Posted by gieso View Post
    Goto my post above!
  11. #9
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    3,769
    Default
    Brrrrrr you guys need to move ! LOL 62F and partly cloudy here.
    Diamond White #B2140 ecosister plate=SLRRYDER
    Crystal Red #C8885, Red-Rider plate=NO2OPEC Hidden Content
    Only 50 gallons purchased, fully charged off Solar , Keeping the utilities at bay.
    DRIVING for FREE! NO OPEC FEE!
  12. Advertisement
  13. #10
    Join Date
    Oct 2011
    Location
    Jefferson City, MO
    Posts
    27
    Default
    Just confirming all the observations made here previously. ICE runs briefly at 25 deg F and then intermittently as needed thereafter. This behavior seems unaffected by garage temperature prior to driving. My garage stays about 50 deg F and it does take a few minutes for the temp sensor to get down to 25 after I get underway. The Owners Manual does a reasonably good job of describing all of the DIC messages.
    BILL GERTH
    Jefferson City, MO
    2012 VOLT (VIN.........CU106509) Delivered 11/2/2011
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Where's the Temperature Sensor for "Ice running due to .."
    By tboult in forum Chevy Volt Accessories and Modifications
    Last Post: 06-08-2012, 07:16 PM
  2. Engine light on. OnStar says "Battery Charging issue"
    By ericner in forum Generation 1 Volt (2011-2015)
    Last Post: 02-11-2012, 07:00 AM
  3. Spanish engineer crafts "world's smallest" V-12 engine
    By Jason M. Hendler in forum Chevy Volt Engineering and Design
    Last Post: 12-05-2011, 10:25 PM
  4. Getting stuck in "engine running due to temperature" mode
    By BxHBxH in forum Generation 1 Volt (2011-2015)
    Last Post: 02-10-2011, 08:57 AM
  5. Experiencing the Chevy Volt Engine Running Due to Low Temperature
    By Lyle in forum Generation 1 Volt (2011-2015)
    Last Post: 12-12-2010, 08:37 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
