Originally Posted by
SharkVolt
You didn't specify whether you had "preheated" the car off grid power, or just got in and started driving. Either way, I find the temperature needs to be set in the mid or high 80s for 5-10 minutes to get decent heat into the car. Then it can be dropped down some and will maintain that temperature.
I just figured this one out, too. I, too, like the idea of a 72 degree (F!) car, but found I was putting it up to 78... and not getting a warm car. I was getting ready to post here or call a dealer to see if perhaps there was a problem (the car certainly uses lots of battery set to 78).
Then I brought a thermometer into the car -- it seems that the heat setting determines the heat that blows on you, not the desired temperature. Having 72 degree air blowing on you in a car that is, say, 40-50 degrees will feel like cold air.
So yours seems to be the answer that works for me -- set the heat up to the 80s, where it will feel warm and more quickly heat up the car, then lower the temperature manually when the temperature is comfortable.
B-2689
Personal Best Charge: 57.2 miles
Best Day: 71.3 miles, no gas (49.9 on full charge, 21.4 on ~4 hours @120V)
Over 4 billion pieces of data collected on the Volt OBD2 port
