Clipper Creek Chargers
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Clipper Creek Chargers
  1. #1
    Join Date
    Oct 2011
    Location
    Newnan
    Posts
    52
    Default Clipper Creek Chargers
    Anyone install the Clipper Creek LCS-25 Level 2 charger in their home? Thinking of going with this charger and curious if anyone had any positive or negative feedback. Thanks.
  2. #2
    Join Date
    Sep 2008
    Location
    my little grass shack
    Posts
    4,553
    Default
    The only real issue is they are rated for the full 32 amps necessary to support "true" Level 2. So unless you already have a 200+ amp main panel in your home (with room for a 40A double breaker) or a sub-panel in your garage- then be prepared for potential costs for electrical upgrades to support it including larger cabling/conduits etc. (even though the Volt itself only techncially requires a 20A circuit breaker for 3.3kw) Correct me if I'm wrong but I dont believe the Clipper Creek EVSEs are not configurable or "strappable" to anything lass than 32A.
    (unless somethings changed)
    WopOnTour
    Welcome Hidden Content as our latest forum vendor!
    Follow the Chevy Volt and other GM electrified cars on Twitter! Hidden Content
  3. #3
    Join Date
    Dec 2010
    Location
    Atlanta,GA
    Posts
    407
    Default
    Quote Originally Posted by Bluejuice71 View Post
    I have the LCS-25 charger installed, and it has worked fine for me. I got it through MetroPlug-In (http://www.metroplugin.com/) of Atlanta. MetroPlug-In also arranged for the installation, and it was all uneventful and well done. I had open positions in my breaker box, and they installed two 25 amp breakers.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jul 2011
    Location
    Virginia Beach, Virginia USA
    Posts
    221
    Default
    I compared the Cllipper Creek with the SPX Power Express. They both have a similar, small profile that I needed for mounting the unit inside a theft protection cage. I went with the Power Express because it can tolerate a slightly wider ambient temperature range.
    2012-01688 Silver Ice Metallic
    2015-05416 Crystal Red Tintcoat
  7. #5
    Join Date
    Oct 2011
    Location
    Newnan
    Posts
    52
    Default
    Sounds good. Metro Plug-in is who I've talked to and have an appointment for a quote. Greg at Metro is a good guy, & said its $650 for install unless tech has to do something unusual as part of the install. I'll let you know what happens.
  8. #6
    Join Date
    Feb 2012
    Location
    Prescott, AZ
    Posts
    13
    Default LCS-25 & Metroplugin
    After researching I decided to go with the LCS-25 as well. Greg at MetroPlug-In helped me clarify some issues around the NEC 625.23 code regarding a lockable disconnect. The unit itself was pricey at $995.00 plus sales tax and shipping. However, my install was a snap and took the electrician ony 45 minutes. The install was completed yesterday, 2/13/12.
  9. #7
    Join Date
    Mar 2012
    Location
    United States
    Posts
    89
    Default
    I had my clipper creek lcs-25 installed today by Metroplugin and one of their install affiliates, Pat Murphy Electric. So far, I've got nothing but high praise for both companies. The service tech, Paul Thompson, did an excellent job and honored their price quote even though it was a bit more work than originally planned (not too much more though).
    The clipper creek unit is small and seems to do the job so far. There doesn't appear to be an LED on the plug for illumination, but that's not a big deal.
    Anyway, I imagine you can find someone to do the job for less money, but unless something goes horribly wrong, I recommend both companies highly. I have no affiliation with either companyr.
  10. #8
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    5,186
    Default
    The LCS-25 looks like a nice basic unit. How much did the unit cost?
  11. #9
    Join Date
    Mar 2012
    Location
    United States
    Posts
    89
    Default
    It's in the $900s...so i guess relatively pricey.
  12. Advertisement
  13. #10
    Join Date
    Jul 2012
    Location
    Sacramento
    Posts
    1
    Default
    The LCS-25 was recently lowered to $795.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. UART Plugs in 240 chargers?
    By beechnut in forum Chevy Volt Accessories and Modifications
    Last Post: 07-06-2011, 01:27 AM
  2. Available Chargers?
    By moshe_levy in forum Chevy Volt Accessories and Modifications
    Last Post: 06-25-2011, 07:33 PM
  3. Charging with third part chargers
    By Rusty in forum Software & Programming/Code Discussions - Chevy Volt
    Last Post: 04-20-2011, 04:33 PM
  4. 1600 Chargers in N. CA soon
    By George S. Bower in forum Electric Vehicle Batteries & Plug-In Charging
    Last Post: 07-08-2010, 06:12 AM
  5. Portable chargers
    By osmigo in forum Chevy Volt Engineering and Design
    Last Post: 10-03-2008, 04:16 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
