LED install in backup light is easy but a PIA
Grab our Forum Feed
+ Reply to Thread
Page 1 of 9 1 9 LastLast
Results 1 to 10 of 83
Thread: LED install in backup light is easy but a PIA
  1. #1
    Join Date
    Oct 2011
    Location
    Timonium, Mays Chapel, Maryland
    Posts
    484
    Default LED install in backup light is easy but a PIA
    I spent about 90 minutes installing a Superbright LED (45HP-LED 16mm Wedge Base 3157 in 6000K white) in the backup light. This is not difficult work but getting access to the back of the light where the LED mounts is a PIA. Previous posts on this mod said that ten screws had to be removed to move out of place the black aero plastic piece the attaches to the bumper and the frame of the car and also encases the backup light. In my experience, it was more like 16-18 (lost count) screws, including two each in the rear wheel wells and three that attach the piece to the frame. Some screws have hex heads, others require a Torx bit to remove. Another PIA.
    I started out using a socket wrench, but realized pretty soon that a screwdriver-type socket mount would make the work go much faster. Once this piece is loose, it's easy to jockey it around to get access the back of the light housing. But if any of the mounting screws are not removed, it's much more difficult to jockey it around.
    One twist removes the bulb socket from the back of the housing and the LED wedge bulb just snaps into place where the wedge incandescent bulb was mounted. As previous posts have mentioned, the LED is much brighter than the stock bulb and provides much better illumination. It did not wash out the view through the rear camera, in fact made it much better.
    My Volt now has LEDs all around and HIDs on the headlamps -- no incandescent bulbs anywhere.
  2. #2
    Join Date
    Jun 2011
    Location
    Ottawa, Ontario, Canada
    Posts
    400
    Default
    My experience was quite similar to yours, maybe things went a bit quicker since I did have a socket driver instead of a wrench. The difference is indeed significant as the stock backup lamp on the Volt is rather pathetic. Personally I found the HIDs more difficult to install than the backup light, maybe it's just my large hands and sausage fingers though
    I didn't remove any screws in the wheel wells though, just on the rear bumper. I didn't get that plastic shroud removed completely, just enough to wedge my hand in between the two pieces of plastic that cover the lamp.
    Did you do your front turn signals too?
    2012 Volt #C6688 Silver Ice Metallic (GAN), Premium Leather Seats with White trim (AFD), Bose Speakers (UQA)
    Placed order June 28 2011, built October 11 2011, drove home November 4 2011
  3. #3
    Join Date
    Oct 2011
    Location
    Posts
    484
    Default
    I'm not good with wedging my hand, so I removed all of the screws. Yes, I have replaced the front turn signals. Talk about hand wedging After that experience I didn't want to do anything like it again.
    I had an easy time with the HIDs probably because I prepared everything in advance and didn't attempt to stuff the ballast into the headlight housing.
    Quote Originally Posted by mike1 View Post
  4.
    Advertisement
  5. #4
    Join Date
    Oct 2011
    Location
    Spokane, WA
    Posts
    73
    Default
    Do you guys have an estimate as to how much the LED/HID upgrades have cost in total and what the approximate power savings are, if any?
    I'm looking forward to these upgrades for both better vision and better aesthetics.
  6. #5
    Join Date
    Oct 2010
    Location
    Albany, NY
    Posts
    385
    Default
    While my Volt was in for the software update I had the dealer install the LED backup light. Labor was $20. Sounds like it was worth it.
    Only GM could make the Volt.
    Viridian Joule #1428
    08/12/2010 Order placed at dealership.
    03/15/2011 Vehicle delivered to customer
  7. #6
    Join Date
    Oct 2011
    Location
    Posts
    484
    Default
    Not including the turn signals, I spent $155 with SuperBright LEDS, but that included a few extra bulbs. So I'd guess about $140. The turn signals were another $60, so the total was about $200. Savings in power will be negligible, but that's not why I made the changes.
    Quote Originally Posted by langosta39 View Post
  8. #7
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,291
    Default
    Quote Originally Posted by artsci View Post
    Given that energy savings are out, why did you make the change? Was it the same reason for all the bulbs? My understanding is that automakers using LEDs are using them for design purposes but obviously you have a different reason.
  9. #8
    Join Date
    Nov 2010
    Location
    San Diego, CA
    Posts
    305
    Default
    It seems that replacing the white backup bulb with a much brighter LED bulb is a great functional improvement. It would be great to see more in the rear view camera when backing up a night. It would also be nice to illuminate more area behind the car at night when the car is unlocked via the fob. I think for these reasons the $25 back up replacement LED bulb is a very worthwhile replacement. If my local dealer would install it for $20 like someone mentioned, that would be great. But I didn't think that dealers would install non GM parts.
    Volt #912
  10. #9
    Join Date
    Oct 2011
    Location
    Posts
    484
    Default
    For better visibility and less drain on the 12 volt battery when the ignition is off. I've done this with all of my cars for about 5 years.
    Quote Originally Posted by DonC View Post
  11.
    Advertisement
  12. #10
    Join Date
    Dec 2010
    Location
    Phoenix, AZ
    Posts
    394
    Default
    Agreed. Better visibility from the reverse. For the parking/turns more of an aesthetic "coolness" thing.
    Reverse LED upgrade is without a doubt a PITA project that is well worth the effort.
    "HISVOLT" C5311 - '12 Diamond White, Light Neutral
    "HERVOLT" D2019 - '13 Cyber Grey, Spice Red
Similar Threads
  1. Backup camera is my only dissapointment
    By JetJock in forum Volt Ownership Forum
    Last Post: 04-17-2012, 01:10 AM
  2. Replies: 25
    Last Post: 01-23-2012, 04:50 PM
  3. WSJ: Facing Up to End of 'Easy Oil'
    By Steverino in forum Politics, Finance, and Environment
    Last Post: 05-25-2011, 09:38 AM
  4. Getting high EEStor yields won't be easy
    By Tom in forum Lithium and Advanced Automotive Batteries and Charging
    Last Post: 08-24-2008, 10:55 AM
  5. Backup Power Connection
    By ozonelevel in forum Suggestions for GM
    Last Post: 03-18-2008, 10:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
