Charge door sensor reads open when closed
Grab our Forum Feed
+ Reply to Thread
Results 1 to 4 of 4
Thread: Charge door sensor reads open when closed
  1. #1
    Join Date
    Sep 2011
    Location
    Geneva, NY
    Posts
    507
    Default Charge door sensor reads open when closed
    Maybe it's just me (or my Volt) but it seems I get the message "Charge Door Open" quite a bit even when it is totally closed. It seems I cannot close it "gently" or I get this message.... anybody else? If I close if quite firmly (almost hard) then it's OK but should the sensor be this sensitive?
    I might have to get on the Buy-Back list! lmao
    '12 Black w/ Dk Accents, Loaded, C2026 (del'd on 9/26/11)
    HID Headlights: 9006 v-leds Premium 5K, ballasts mounted outside canister.
    LED Frnt Turns: 7443 7.5w HP Amber, Backup: 3157 CREE 7w HP 6K License: (2) 194 2w 4-LED HP Flank 5K, Backseat: (2) 194 2.5w 6K, Cntr Console: (1) 194 2w HP 6K, Center Map: (2) 194 2.5w Red, Cargo: (1) 194 2w Flank 6K, Vanity: (4) 3022 1w 5K
  2. #2
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,801
    Default
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 32,109 miles, 143 MPG, Remaining Oil Life 98%
    Typical Commute: 57-67 miles
    30 day Stats: 1288 miles, 250+
    MPG, 87% Electric, 13% gas, Saved 52 gal., 24 kW-hr/100 miles
    VOLT TIPS & SECRETS
  3. #3
    Join Date
    Oct 2010
    Posts
    1
    Default There's a fix for that
    Same thing happened to my Volt. The tech tried to adjust it but GM finally ordered a replacement door assembly. Problem solved.
  4.
    Advertisement
  5. #4
    Join Date
    Dec 2010
    Location
    New Jersey
    Posts
    815
    Default
    Yes, you need a replacement door assembly. Known issue with early build cars. I had mine replaced, and it's been fine ever since.
+ Reply to Thread
Similar Threads
  1. Charge door occasionally refusing to open
    By Bert in forum Suggestions for GM - Chevy Volt
    Last Post: 02-18-2013, 08:55 PM
  2. Charge door open while on the highway
    By AllenL in forum Problems/Issues, Driver Warnings or DTCs -Chevy Volt
    Last Post: 12-16-2012, 01:09 AM
  3. Charge Door popped open while driving
    By lambdapro in forum Chevy Volt Owners Forum
    Last Post: 11-15-2011, 08:34 PM
  4. "Open Door" ding happens when I shut the door, and then also when I lock it.
    By ssj4vegita2002 in forum Problems/Issues, Driver Warnings or DTCs -Chevy Volt
    Last Post: 03-27-2011, 10:51 AM
  5. charge door
    By doubledave in forum Chevy Volt Owners Forum
    Last Post: 02-05-2011, 09:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
