Cruise Control and Shift in low
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
Thread: Cruise Control and Shift in low
  1. #1
    Join Date
    Sep 2011
    Location
    Las Vegas, NV
    Posts
    19
    Default Cruise Control and Shift in low
    During my dealership delivery training I ask the question if they knew if I could coast down hill in low with the cruise control set to the speed limit and maintain the speed set without touching the breaks. They did not know since maybe cruise costing in low would be seen as applying the brakes and kick you out of cruise.
    Well I had to test that, so I took a trip up to Mount Charleston and Lee Canyon ski resort at 8000 plus feet. I used MM on the way up as I had to test the engine. It worked as expected and I consumed 2.2 gals of gas in cruise at 55mph on the way up. (5000+ foot climb) I did not log the miles, but the car reported 35.5 mpg in CS. On the trip down I set the cruise at 45 mph and in Low all the way down. My Volt maintained 45 all the way and regen added 27 miles to the battery range till I came to HyWay 95 and the trip back to Vegas at 70mph all on battery. It was so great to see the battery range going up as I was heading downhill on the long run.
    Bottom line: the volt will hold speed on the down hill and stay in cruise till you hit the break pedal ! !!!
    Has this topic been discussed on this forum before? I did a search and came up empty.
    Bob
    C8329, White Diamond with light interior. And I do love the looks of this interior.
  2. #2
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,419
    Default
    You may be the first to test this, bglasvegas. Nothing beats a real world experience. Regrettably, not much opportunity to test driving down a mountain in cruise with L around Chicago, hahaha. Thanks for sharing!
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 140 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  3. #3
    Join Date
    Jul 2009
    Location
    Colorado Springs, Colorado
    Posts
    2,850
    Default
    It has been discussed before, but the search function is pretty broken so its probably okay to revisit things when there are many new owners. If you tried and could not find it, maybe they cannot either.
    I know I posted about it when I did my trip down loveland pass it was very effective. My trip includine continuing on I70 in CO, and I significantly extended my range. (75M on a single charge) even with CC holding my speed down to 65mp or 70mph.
  4.
    Advertisement
  5. #4
    Join Date
    Dec 2010
    Location
    West Virginia
    Posts
    766
    Default
    I found cruise control to do a good job either uphill or downhill. I've driven across the mountains on I-64 to the Virginia border from Beckley, WV and across I-68 from Morgantown,WV to Cumberland, MD. I've never seen the speed vary by more than 1 unit (mph) either up or down. Sometimes the cruise control will overshoot by 1 unit when transitioning from one angle to another, say at the crest of a hill.
    It would be interesting to know how the cruise control is tuned. I assume that it is some sort of adaptive control that changes the gain and reset as speed and engine load change.
    WVhybrid
  6. #5
    Join Date
    Oct 2011
    Location
    Portland, Oregon
    Posts
    74
    Default
    Quote Originally Posted by bglasvegas View Post
    Bob
    Great information as I live in mountainous area too ( Western Oregon). I don't fully understand though, if you drove on MM to the top, then didn't you already have 17 miles of battery left over for your trip down, so gained only 10 (not that that is bad mind you). My question though is if the electric motor is working harder to drive the car in low range, wouldn't it have used more battery? I would wonder what your results are doing the exact same trip but in D on the way down. I know for me to coast down a hill in low, it has to be one heck of a steep hill.
  7. #6
    Join Date
    Sep 2010
    Location
    San Diego, CA. VIN B-95
    Posts
    2,631
    Default
    Quote Originally Posted by Robinpdx View Post
    I'm not sure you understand the difference between D and L. They don't change any gearing in the Volt, and the motor doesn't have to work any differently in L versus D to drive the car, as long as you have your foot on the accelerator (enough).
    All L does is map some regen into the very first bits of the accelerator pedal play, so lifting your foot off the accelerator causes increased regeneration compared to driving in D. If your traveling on level ground at 90 MPH in L, the motor is working exactly as hard as it would be if you were driving the car at 90 MPH in D.
    As for coasting down hill, if you've got the cruise control on in L the car will engage regeneration to keep you from going over the set speed. It won't (at least my '11 won't) if you're in D, and the car will coast down hill faster than the set point on a steep enough hill.
  8. #7
    Join Date
    Sep 2011
    Location
    Las Vegas, NV
    Posts
    19
    Default
    Nope; I added 27 to the 14 left after returning to normal mode. Rusty is correct. Driving in D down hill in cruise, the car will not hold set speed. But in L, all is good!
  9. #8
    Join Date
    Apr 2008
    Posts
    1,385
    Default
    Thanks for the info, it's really good to know that.
  10. #9
    Join Date
    Aug 2008
    Location
    Anderson S.C
    Posts
    1,088
    Default
    I like to have control of my car and try to avoid Cruise control because I can anticipate situations where I need to speed up or slow down and react faster than the cruise control. I have to admit the I would love to have had the optional radar controlled cruise control on my Lexus. It knows when you are getting too close to another car and backs off. C/C is great because it allows you to relax your right leg on a long drive but if you don't pay close attention it can be a hazard.
    I don't know it this is true or and urban legend and it could be true because there are no limits to people stupidity. But the story is that someone in a new motor home wanted to make so coffee so the flipped on the C/C and walked back to brew coffee with no one behind the wheel.
    There was even a scene in a movie that had the motor home coffee incident
    I checked ut snopes, here is a link
    http://www.snopes.com/autos/techno/cruise.asp
  11.
    Advertisement
  12. #10
    Join Date
    Dec 2010
    Location
    Houston, TX
    Posts
    1,481
    Default
    Since when did cruise control also control the steering of the vehicle???
    That's the dumbest myth I have heard in a long time, and I wouldn't want to be the one to perpetuate it on forums.
    Quote Originally Posted by silvercorvette View Post
    Volt #947 Delivered on 2/25/11 -- Sold!
    240V Blink Installed 10/28/11 -- Returned!
Similar Threads
  1. stick shift in an EV
    By excess_3 in forum Engineering and Design
    Last Post: 11-30-2011, 09:53 PM
  2. Thoughts on D,L, and Cruise Control
    By wainair in forum Volt Ownership Forum
    Last Post: 10-22-2011, 06:09 PM
  3. GM to add second shift at Volt plant
    By scottf200 in forum Chevy Volt News and Events
    Last Post: 03-11-2011, 11:56 PM
  4. Minor Problem - Cruise Control "Typo"?
    By MichiganVolt in forum Volt Ownership Forum
    Last Post: 01-29-2011, 09:29 PM
  5. G.M. in Shift from Trucks Toward Cars
    By Joshua Bretz in forum Chevy Volt News and Events
    Last Post: 06-03-2008, 08:47 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
